Aussieveedubbers 路 VW Drag Racing
GARAGE SALE
https://forums.aussieveedubbers.com/threads/59604/garage-sale
RodPenrose 路
Well I am buying a pauter engine for my new race car and need to move some stuff . I am selling the whole lot of engines and spares that I have gathered over the past 15 yrs . I would say there is approx $ 80,000 in full engines and related spare parts that I no longer require and will sell to finance the new engine . I will be making a list of all engines and spares soon . First I would like to offer you my 86mm x 101.6 mm Autocraft engine complete turn key including turbo , fuel system and clutch for $ 11,000 , I have dyno sheets for this engine that say 548.9 hp .This is one of 3 Autocraft's I have as well as Scat cases ,a complete ARPM engine , 6 other good 2300 cc street engines , 75 caburators , 15 cranks , 23 sets of conrods . 9 new cases , 18 sets of pistons/cyl , 13 prs of new and used heads , 6 sets of 48 ida's , fuel inj manifolds and the list goes on , ROD , 02-42729920 8am-8pm .
[ Edited on 16/1/2007 by RodPenrose ]
Dasdubber 路
That is one garage sale I'd love to attend!
Best of luck with the sale Rod, unfortunately I'm not endowed with $ at the moment but hopefully you'll get some serious interest. 馃憤
Spellbound 路
Where you at Rod? And what sorta Carbies??
Edit: Kembla Grange obviously! 馃榾
[ Edited on 15-1-2007 by Spellbound ]
MattY-64 路
Hi Rod,
Is this an on location garage sale only or will you be unleashing everything on the forum?
Have you got any wild 1600 dp ? (prolly nothing that small) :-)
Matt.
dangerous 路
Give Rod a ring is your best bet.
Good to deal with and probably has the bits you need, new or used.
He has carbs from stock up to 58mm berg, so there is most likely something for you there Spellbound(sorry don't know your name)
reub 路
I was in heaven when meeting Rod and being in his shed.
Awesome :thumb
....now, where do I get some funds from for that drag car Rod???
humpty 路
reub-revhead wrote:I was in heaven when meeting Rod and being in his shed.
Awesome :thumb
馃槀馃槀馃槀馃槀
I was thinking just the same thing......
Doug Sweetman 路
Or how about Rods 500 horsepower Autocraft big banger....... and Dave Butlers Millenium bug shell, grab a suitable gearbox and some front suspension etc...... you would have an 8 / 9 second drag bug for less than the price of a new commodore......
humpty 路
Hush Doug.... Im trying to get a deal together here..... Hush!
greenman 路
C'mon Rod. My wallet is collecting dust....
RodPenrose 路
Ok , guys get your money out , I have a type 4 engine built on a '79 2 ltr case , welded 78mm crank with std type 1 rod jnl's , scat 5.5'' H beam rods with 3/8 bolts , JE 103mm pistons , webcam 86 B with straight cut gears , scat lube-a-lobe lifters , dual tapered pushrods , pauter large bore tubes AND pauter mega pro heads fitted with 55mm x 43mm titanium valves - 1.550'' dual springs and dampeners - crower titanium retainers - pauter 1.4 roller tip rockers , all just freshened with an optional up-right cooling kit for the bargian price of $ 8000 . No hp figures as yet but you must have a good transmission , ROD , 02-42729920 .
reub 路
man....馃檯
RodPenrose 路
I have found another complete engine that is suitable for a buggy , baja or off road car . It is a 2304cc built on a Brazillian case , 83mm scat pro comp crank , 5.5 scat h beam rods , mahle piston/cyl's , fk89 with 1.25 rockers , ported street eliminator heads with 44mm x 37.5mm , melling oil pump , jay cee tubes and 48mm idf carbs . This engine was used in one of my own cars for about 500 km's and has been stiiing for 5 1/2 years . This engine is 100% complete with all cooling , off road exaught that sits beside each carb , charging system and kennedy clutch all for $ 4800 , ROD , 02-42729920 .
mcharlton 路
Any complete engines suitable for a Beetle?
humpty 路
mcharlton wrote:Any complete engines suitable for a Beetle?
It wouldn't be tough to make that 4K deal fit a bug I'd reckon?
jason1957 路
Hey Rod put me down for a set of 48idas or bigger if you still have some. Do they come with manifolds, linkages and aircleaners or are just the card bodies???
I want to put them on my 2.0ltr type4 (will be bigger than this at some time in the near future). I may be able to get a hold of some type4 manifolds for these but would like to buy them complete if possible.
Any other type4 gear????
U2U me some prices when you work them out.
RodPenrose 路
I am still cleaning up and have found another engine kit that I can put together , so you will get an Oxy-boxer case machined and bored for type 4 mains , 88mm pro comp Scat 8 dowelled crank with type 4 mains and porsche jnl or you can up grade to a flanged 88mm instead , Carrillo rods in prosche jnl and 5.7'' , JE 96.7mm pistons with gas ports , notched with rings and Autocraft barrells , Autocraft pro-series heads with 50mm x 40mm stainless valves and fresh port job with valve covers , Autocraft 1.25 pro-series roller rockers , Scat type 4 lube-a-lobe lifters , lightened 8 dowelled flywheel , moly gland nut , Pauter cam X-8 with 305 @ .050 and 447 lift , Jay Cee pushrod tubes and un-cut Autocraft dual tapered pushrods all for the bargain price of $ 6000 , thanks ROD , 02-42729920 .
RodPenrose 路
I have enough parts here to build a very quick 2276cc engine that is suitable for drag racing . All components are brand new and still in boxes , assembly can be arranged for an extra $ 400 .
Bugpac high roof case , opened for 94mm , clearanced for 86mm , 8mm inserts installed , solid behind # 3 cyl , tapped for full flow and shuffle pins on centre mains
Wedgemated Demello 82mm crank , std mains , std vw jnl , with lightened flywheel and shim pack to suit
Super flo heads with 44mm x 38mm stainless valves , dual springs , valve covers and polished IDF intakes
CB performance H beam conrods in 5.5''
Mahle 94mm piston/cyl kit
Engle fk 87 or 89 camshaft
Scat solid lifters
Full set of bearings
Gasket kit with Rear main seal
All for $ 4700
I also have these new parts to complete the deal
Scat 1.4 pro rockers
Scat cro-moly pushrods - un cut
Scat Aluminium adj. push rod tubes
CB maxi 3 full flow oil pump
Rebuilt 48mm Dellorto or Webber carbs
1 5/8 ceramic merged headder with stinger
copper exaught gasket kit
For an extra $ 1600 bringing the total to $ 6300 . thanks ROD , 02-42729920 .
humpty 路
What an absolute bargain!.... If I didn't have most of that 2276 stuff already, I think I'd be buying this one!.... This is some sort of cleanout your doing here Rodney!
馃檪
[ Edited on 24-2-2007 by humpty ]
RodPenrose 路
I have a CB performance turbo system that I haven't had time to use so it is up for sale , you get the 1 5/8'' ceramic coated hide-a-way exaught , T3 turbo , wastegate , tube from turbo to crossover pipe , crossover pipe , turbo hats , deep sump with oil drain fitting , oil lines in and out of the turbo , pipe and air cleaner , all hoses and clamps , all brand new and straight from CB for $ 2400 . I also have some 48mm throttle bodies , injectors and fuel rails that will complete this deal . This system is designed to fit into a beetle with no body modifications , ROD , 02-42729920 .
bond 路
fkme
VWCOOL 路
wish I could 'find' stuff like this in my shed!
