FS Subaru ej20 turbo & conversion kit
https://forums.aussieveedubbers.com/threads/59764/fs-subaru-ej20-turbo-conversion-kit
seagull ·
seagull Neil
Perth wa
0407074141
Subaru ej20 turbo motor low K jdm unit , VF10 turbo
c/w full harness & ecu c/w adapter plate & 200mm fly wheel to suit air cooled manual trans .
$1600.00
also 1800 kombi gear box for the above $400.00
Due to upgrading the drive line of my bug the above is no longer required .
seagull
one4 ·
U2U sent
Richard
dammit too slow
why is all the good stuff on the worng side of the country....
boof2332 ·
Is it sold???
I have an engine if you want one...
Hey Neil, did you hear that we had issues with starter motors on the kombi and chewed out the ring gear on one of the flywheels i got off you. F##k it. Maybe I can machine off the gear and weld on new ring gear..
What do you think..and please do not tell me its a throw away.
Matt
seagull ·
No matt nothing here .
I have only seen that with a 6 volt starter , just about every one uses a auto starter .
from what I have seen kombi 223mm fly wheels are all cast iron with a pressed on ring gear made of steel you could repair it that way .
