Hi guys, Im about to lower my 69 notch and its currently sitting on 15 x 6 wheels.
I was wondering if i should run standard 15 x 4 or 15 x 4.5 wheels on the front and where about i could pick up two of these on the gold coast ? Thanks, all feedback appreciated . Ben
bond ·
put a wtb post in parts for sale and see how you go. depending how low you go. may run 135 tyres on the front.
whereisfelicity ·
thanks bond
sinecure ·
Nick can tell you LOTS of interesting things about dragging your arse on the ground.
"Did you lower the car, sir? Why did you lower the car, sir?"
humpty ·
If your planning to salm, then the OG rim is your best bet with a small tyre.... Personally Im not a huge fan of the low tech 135 Michy, but that will do the job.... I've had 145/65-15 Conti's on the front of my Notch which was fine.... But I wanted to go even lower and fit bigger rims and brakes, so have fitted a much modified TI LP beam under there... Now I can set the car to drag if I wanted (but why would I want to wreck my car??!!) and she still rides a treat.... The stock rim with a small tyre knocked down a couple of notchs had you will still be rolling nicely.... Give that a shot.... If you want more, drop me a line....
