how low on k&l beam
https://forums.aussieveedubbers.com/threads/59872/how-low-on-kl-beam
57oval ·
How low can you go on stock width k&l beam on 165/80/15 ?
[ Edited on 24-1-2007 by 57oval ]
ruckus ·
What profile on the 165s? I don't mean to be a smartarse but my 165x45s would go much lower than the standard 80 profile.
Hertz ·
Not very low. Go to some 145/65 15s, then you can almost lay pan before you scrub on anything.
oval TOFU ·
Hertz wrote:Not very low. Go to some 145/65 15s, then you can almost lay pan before you scrub on anything.
rupewrecht ·
As low as mine...but i've got drop spindles as well. i think it's about 11cm off the ground
Hertz ·
rupewrecht wrote:As low as mine...but i've got drop spindles as well. i think it's about 11cm off the ground
Except you have a 3.5 inch beam. With a standard width beam you will tear your gaurds off if you try to go that low on 165s.
oval TOFU ·
rod-it then... no guards!
rupewrecht ·
yeah fair call - forgot about that!
57oval ·
i have droped the front down 1 inch over the wheel, drives ok just a slight rub on full lock .might try some early T3 wheels different offset.
BOOMERDOG ·
my '54 oval runs firestone 125x70 15's on the front on stock rims ,slight narrowed beam, can take it virtually to the deck.... no messin'..:thumb
[ Edited on 25-1-2007 by BOOMERDOG ]
