Well what have we got here?
Note: More to be added later!!
Check further posts for additional items.
Some stuff left on nature strip, some I didn't put out.
68-on lowback Red vinyl seat covers 2x front (top & bottom), plus rear top half, back panel, 1x front seat top half frame, 1x back seat top half frame + padding. Vinyl is still on nature strip.
Original style 2 piece rubber matting for beetle floor - some tears but useable! I don't want to use it. Carpet underlay material for sound deadening for the rear half. Gone to Hertz
Carpet panel for RHS heater channel & vent. Good cond. Dunno whether this is still there
Clutch and pressure plate. Its got meat left on it. Gone
Homemade 10 inch MDF sub box. Finish it off or use the MDF for something else. Firewood
Its all going out on the hard rubbish pile Sunday night so be quick.
Pickup only, by tomorrow night!! Its got to go!
Better for me to post this stuff on here with the hope that it can be put to use than just chuck it on the pile for the scavengers.
Call me
Steve 0422669966
Blackburn 3130
[ Edited on 3/2/07 by *did* ]
[ Edited on 4/2/07 by *did* ]
[ Edited on 5/2/07 by *did* ]
*did* ·
Pre-67 set of glass minus vent windows, will throw in some chrome window trim too
Didn't put these out. Let me know if you want them. Will throw out eventually.
Hertz ·
Will grab the rubber floor Stevo. U2U your address mate, will come over and grab it.
Hertz ·
I might hang around your house, I love hard rubbish! Free old stuff:thumb
hipichic ·
Hard rubbish furnished my dining room practically 😉
Love it!!
*did* ·
More stuff:
- 2 z-bars (those bars that attach to the rear axles and the body on '68 on swing arm beetles) Gone.
- 2 twinport heads - 1 needs a new helicoil and the other has had some burning in the combustion chamber but should be ok. Didn't put these out. Let me know if you want them
- doghouse fan shroud. good condition just needs paint! Ditto
Get on it if you want it!!
*did* ·
set of 4 red vinyl door cards, ok cond. Ditto
*did* ·
3 engine cases + bits $150 lot:
- 1 type 3 'T' code case, with p&c's, flywheel, complete internals, most if not all tinware, fan housing, oil cooler, nothing else
- 1 'H' code case, complete internals, flywheel, nothing else
- 1 'AS' code case, complete internals, flywheel, clutch, nothing else
- 2x pairs rocker arms & shafts
Note: cases have not been split, just stripped down to the short block (i think thats how you describe it anyway).
*did* ·
bump. didn't put some bits out so they are still up for grabs, see posts above
*did* ·
*did* wrote:3 engine cases + bits $150 lot:
'AS' case sold. Remaining cases + type 3 tinware and stuff $110 lot
Type3Sicko ·
Steve , you have u2u re: glass and other S$%T. thanks, A
