Flywheels
https://forums.aussieveedubbers.com/threads/60138/flywheels
DubCrazy ·
Was going through some of the engines i have sitting in my shed and i noticed that one of them has a smaller flywheel, they are all 200 clutch plates but one has a smaller diametre(less teeth). I know this engine came out of a later bug than the rest earlier. Anyone know why? is it 6volt/12volt?
seff......................
xornge666x ·
The one with smaller pitch teeth is 12V. (more teeth and larger diameter)
The one with larger pitch teeth is 6V. (less teeth and smaller diameter)
Grey 57 ·
The 200mm clutch one that's smaller with less teeth will be early Type 3 (6volt).
xornge666x ·
Grey 57 wrote:The 200mm clutch one that's smaller with less teeth will be early Type 3 (6volt).
most likely with a stepped crank.... just check the crank and your end float..
DubCrazy ·
thanks for that... thought it was the 6 volt/12 volt sizing....
steff..............
