Someone mentioned that you can fit Kombi torsion bars into a beetle (rear). Is this the case? Be great if it is, as there is a lot more Kombis around than Type 3 wagons!
:jesus
No sorry there the wrong size
Only Type 3 ones will fit not KOMBIs
KruizinKombi ·
While the topic is up, how much are squareback torsion bars worth?
MR930 ·
I've got some type 3 wagon ones for sale . I was hoping to get $50 for the pair . Mark
Secoh ·
Mark, if you can bring them down next time you are in Newcastle, then I'll happily swap you a $50 for 'em 🙂
or use 944 porsche ? $100 a pair from wreckers ! will fit and are the same size as T3 apparently.:thumb
Type 3s usually sell for $100.00 a pair..
I got a set if anyones looking
and what a nice "set" you have :kiss
MR930 ·
No worries .
type82e ·
ive got a set of type 3 torsion bars how can you tell waht they came out of ie/ squareback fasty notch?
marcel
all the same.
KruizinKombi ·
I thought the square's were thicker?
Buggy Boyz ·
They are not all the same, the wagons had thicker ones, I think 23.5 but would have to check. They went as low a 21.5 I think.
Anyway they are differentm measure them to find out for sure.
Hi Secoh
You can get thicker aftermarket bars for 944s but they might be expensive. You might be better off going coil overs on the rear.
Below is all the Type 3 torsion bar versions. Fastbacks & notches use Beetle size bars.
