kombi box in beetle??
https://forums.aussieveedubbers.com/threads/60149/kombi-box-in-beetle
kroozzn63 ·
i can get a 69 baja with 1916 efi motor fitted to kombi box ,with mods can u fit motor and box in a 63 beetle??
hellbugged ·
yes, but you would have to go IRS to start with.......and then some
crewcabconnection ·
Bren, you need to stop all this Beetle talk and but a Kombi box in a Kombi ... come home Brendon ... you know you want to.
kroozzn63 ·
and then some ? the baja is on a irs 69 ball joint front end hmm maybe a body swap $$$$$$$ or leave it and get a kombi when i can a deano
hellbugged ·
body swap....for sure, say goodbye to wide 5 and enjoy the improved handling and stopping
kroozzn63 ·
the bajas got adapters up front and wide 5 on the back drums i think?
hellbugged ·
all good then, just thought you were the type to want the wide five....have you had a look under the baja?....hows the box link up to the gear shift shaft?
kroozzn63 ·
ill have to find out heres a pic
koolkarmakombi ·
body swap and an extra extra long set of hoodjax?
hellbugged ·
keep in mind, body swap would require a "blue slip" inspection and re-registration.......
........getting the whole baja?......
you could always i.r.s the swinger, weld in arm pivot boxes (make a jig from the baja), dimple frame horns for c.v clearance, relocate handbrake ends on the frame horns, change spring plates and go to some heavier torsions whilst your at it..........big job either way you takle it, but many benefits.......
some kombi box conversions use a "adapter" front housing so the shift linkage doesn't require moding, that will be another job if it's not set up as such.but you have an existing set up to work off, so the blueprints are all there for the taking hey!
