contact matty 64 as he has some coil overs for sale ,im getting a set for my baja ,they should be good for yours as well ,what year model is your baja ?
Lots of ride height and plastic bushes!
Learner ·
mine is a 1969
64vwmark ·
I wouldn't go for coil overs, they make the suspension too stiff.
I would look at beam adjusters for the front and I would adjust the preload on the rear torsion bar to make sure that you are using the full suspension travel. Apart from that, I would look at getting some decent shocks like Bilsteins or Konis if you can afford them.
A VW will go along way off-road with just a modest lift of teh suspension: You will need to modify (cut and weld) the front beam with Selecta-drops and lift the rear suspension by adjusting the torsion bars, as oulined in a service manual (ie Gregories/Haynes etc)
Add some knobby tyres and voila! :thumb
Learner ·
i really like what Sandy has got at the front. what is it?
64vwmark ·
Learner wrote:i really like what Sandy has got at the front. what is it?
Show us a picture, then I'll tell you.
I have to recommend the perfect book for you. It's "Baja Bugs and Buggies" by Jeff Hibbard. It will answer all of your questions. A lot of the modifications in there are cheap and more importantly, they work!
Anthiron ·
sandy has a king and link beam which is raised and he runs longer than stock trailing arms (illegal)........but yeah i like it too 🙂
hellbugged ·
im running a country buggy front and raised irs rear..........it aint a baja tho😎
Learner ·
ha yes illegal stuff. it's beautiful though. i can't remember wher i saw the pic but nice.
Learner ·
does a narrowed beam means you can use wider tires? (i know it's useless for a baja to have wide front tires)
Baja Wes ·
Here is a pic of Sandy's front end, and my thing type 181 front end. I think the thing is the best option.
Learner ·
so sandy's suspention is actually illegal? so wes... what's the differance beteenw yours and snady's? i mean looks like sandy's got more clearance?
Learner ·
MickH ·
Wes runs stock VW parts.Sandy doesn't. The 181 and IRS combo would be the best IMO,stock legal parts and ample travel with street drivability.
[ Edited on 21-2-07 by MickH ]
Sandy ·
What he said 👍
Baja Wes ·
I also run mine at standard height, it's not raised. I have my adjusters set in their lowest position.
This gives better steering (less bump steer) as all the steering geometry is still stock.
newoldmanx ·
is it true that you have to modify(lengthen) the frame head to run longer arms??? and can you run long arms on a thing front end legality doenst concern me as its all good here 😀
[ Edited on 26-2-2007 by newoldmanx ]
Sandy ·
Yes you have to lengthen the frame head or the tyres will smack into the body when the suspension compresses. I don't know if anyone makes long arms for ball joint.
Learner ·
hm thanks guys all is good help.
Learner ·
i got a 1969 100 so i would need to convert to irs ... how much does it take to do all that? irs- 181suspention.
Learner ·
what does it take to tranfer a thing front? also what shocks are recomanded?
