Anyone recommend a type and specification of sway bar- I have a 64 Beetle with King/Link pin front end and swing axle rear- It has the camber compensator on the rear already and the standard old sway bar on the front.
Any advice- experiences- I use the car for club events, street sprints etc.
Peter
vwrallycar ·
talk to pedders or similar and see what sizes are available.
remove the camber compensator and fit a sway bar out back.
hellbugged ·
yep go the sway bars front and rear......18mm front & 22mm rear, grab the adjustable ones and dial it in:thumb
a sway bar on the rear of a swing axel car is a no no,it will promote axel tuck when you start to corner hard,the early beetles have a high roll centre and you will reach a point wear the car is going around the corner quickly and it will go into snapover steer,if the camber compensater is a swayaway keep it,lower the car in the rear about 1.5 inchs and limit the downward wheel travel,you can purchase a thing called a flop stop which attaches to the spring plate where it hits on the rebound stop,this will limit the amount of positive camber and make the car safer to drive quickly,replacethe front bar with 19 mm diameter one,check the alinement and fit castor shims if required,my beetle , a 60 model is set up basicly this way running 7x17and8x18 and handles fantasticly,totaly nutural and can 4 wheel drift with no surprises,i have tried all of the combinations over a long period of time .my rear sway bar was removed and given to my brother who owned a car with irs,the camber compensator helps stop axel tuck good luck
hellbugged ·
vwo60.....what sort of bars did you run out back and how did they attach to the suspension?
vwo60 ·
k mac attach the same way as they all do,two clamps around the torsion bar housing and attached to the lower shock bolt dangerous,sway bars on the back promote oversteer in swing axel cars a camber compensator effectivly helps control axel tuck at the expence of body roll i lived with that set up for about a week, it did improve the handling to a point but after it got nasty with a quick transition to overstear ,fitted acamber compensator and fixed the problem
hellbugged ·
what were you running up front when you were experiencing the "snap" oversteer?
vwo60 ·
a 19mm bar with bilstiens all round if you would like to confirm what i am saying please refer to a good tech book'how to modify volkswagen beetle suspension & chassis for high performance'by James Hale.sway bars for irs,camber compensator for swing axel,sway bar on the rear of a swing axel raises the roll centre the more load that is applied during fast cornering,the sway bar then trys to keep to body roll in check but as roll centre changes so dose the centre of gravity raising the rear of the car and ends up with max positive camber as the sway bar tries to keep the axles level with each other which it dose well, a camber compensator works the opposite,as the wheels try to go positive the spring is trying to keep the axles parralell thus avoiding the axle tuck which is promoted by the sway bar,but you pick up some body roll,its all a compremise,list of cars i have owned and modified, 1 L/P-S/A sway bar-camber compensator 2 L/P-IRS sway bars 3 BJ-SA sway bar-camber compensator 4 BJ-IRS sway bars
hellbugged ·
yeah just wondering, not doubting your results, experiments or opinions.i'm running whiteline bars front and rear, they attach to the spring plates tho....i'm not getting snap oversteer at all, it's very neutral.........i'm running one notch (inside) lower in the rear...maybe the forces stop being transferred so much when the outside sits on the bump stop
BrisDubba ·
This is a pic of my camber compensator- not sure if you call it a swingaway.. the car is already pretty low and I have the caster shims in the front.
BrisDubba ·
side...
vwo60 ·
the bar you have appears to be from sherman,it apears to be pulling down on the axle tubes and in your photo you can see the elongation of the whole punched in the strap that goes over the axle tube,this is not correct,it should be appling force up onto the bottom side of the tubes ,the sway a way camber compensator has no straps,it is held in position by the spring tension and it has a proper pivot in the centre with a through bolt and urathane bushing and applies pressure to the bottom of the axle tube all of the time.go to 'sway-a-way suspension components,on google and look under vw suspension while you are there check the listing for sway bars for vw and you will find that sway-a-way does not make a rear sway bar for the swing axle just because there made dose not mean there are right ,purchase the book i mentioned previously from drysdale auto books in bowen hills ph 38525075 and learn how the whole thing works
