kombi windscreen washers- electric pumps
https://forums.aussieveedubbers.com/threads/60406/kombi-windscreen-washers-electric-pumps
kombi_kid ·
hey
just wondering what electric pumps have been successful for windscreen washers in kombi's have tried the dick smith pump but it just doesnt have the balls to pump water upwards to the washers so what have people used??
rhys
greedy53 ·
went to a wrecker and grabed a holden tank and pump it fitted nicely into the front of the bus i have used two pumps to get a long distance for a differant project worked great
kombi_kid ·
mmmm thanks mate will give one a go
rhys
Go along to Super cheap ( or similar ) they have after market pumps there for about $15 new I have used them on my Beetles no problems
Just have it under the water tank so it gravity feeds easy to hook up with a micro switch in the washer arm of the steering coloum
kombi_kid ·
hey dave
yer beetles are all right cause there on about a 45 degree angle to pump water up problem with kombi's is its straight up.
rhys
xornge666x ·
I've fitted plenty of them to buses... you should not have a problem.
Blow some compressed air gently through the lines and nozzles, maybe they are slightly blocked.
Rhys
Its squirts out with heaps of pressure get one of the after market ones Easy
from where mines located it would be about 500 mm rise make sure you gravity feed the pump from the water tank, and as per above make sure the nozzels arnt blocked clean with a pin n air
