Aussieveedubbers 路 Non-VW Engine Conversions
02m/Ford bellhousing
https://forums.aussieveedubbers.com/threads/60494/02mford-bellhousing
mwstewart 路
Hello guys,
I would like to mate a Ford Focus engine (2.0 Zetec) to an Audi/VW 02M 6 speed gearbox. Adapter plate seems like the easiest option here, so my question is what's the best way to go about it? I understand the holes and dowels have to be incredibly accurate so what is the safest way to measure them?
Cheers for any help,
Mark
[ Edited on 15-2-2007 by mwstewart ]
sinecure 路
Ask Seagull (Perth, WA).
馃憤
seagull 路
ok
if the holes work out so you can plot them out on a mill with X Y Z your in luck .
if they dont
work off the center of each item
1 ) the motor .
It has a center bearing in the crank , you need a shaft that fits in that , some thing of quality .um lets say a front strut from a car ( good thinking seagull ) , cut the shaft out & get one end machined so it fits the center bearing .
2) you need the bolts that fit in to the motor housing machined to a point facing out .
3) you need the plate you are going to make the adapter plate out of with a hole the same size ( od ) of the strut ( shaft )
4) slide the plate down the shaft & with a hamer tap around were the points are note they all need to be the same lenth from the back of the motor ( face )
you have now marked the motor side .
gear box is the same , you may need a sleve for the gearbox shaft
or now place it on a face plate in a lathe & clock off the center hole .in doing this machine a step that the plate will sit in the gear box , remove from the lathe tap in to the gear box bolt the motor up so the gear box is in the correct position & mark the holes with a scribe ( fine point marker )
remove & drill the holes
fly wheel will do your head in its all measuring
Mark fill in your location so we know were you are
I hope this helps < seagull
sinecure 路
Told ya.
LOL 馃槈
seagull 路
I know I need help dont I !
馃お
mwstewart 路
seagull that's a very nice solution to the problem, cheers! I'm going to have a crack at it this weekend.
:beer
