Aussieveedubbers · VW Circuit Racing
Racing Harnesses??
https://forums.aussieveedubbers.com/threads/60614/racing-harnesses
Ian Bugden ·
Hi,
Where is the best point/s to attach a racing 3 or 4 point harness? I have seen people attach them straight down from the seat back and I am led to belive this is dangerous as it will break the seat into your back if you have a crash. I do not have a roll cage so am thinking of the rear firewall but there are no anchor points there.
Where do you suggest???
Ian.
BiX ·
With no cage, i mount mine through the rear fire wall. Have a 3mm thick, 40mm wide piece of flat across the engine bay. (check min required dimensions from cams or andra).
david777 ·
This is how mine are attached. Between the harness mounts I have also added a child seat mounting point.
[ Edited on 22-2-2007 by david777 ]
amazeer ·
Its recomended that the harness is within 10 degress below horizontal but 40 degrees is acceptable. http://www.camsmanual.com.au/pdf/0609_0701.pdf
