kafer70 ·
Is anybody running 88mm barrels & pistons ?If so what do you think or has anybody got some info.:P
https://forums.aussieveedubbers.com/threads/6063/88mm-bp
kafer70 ·
kafer70 ·
kafer70 ·
kafer70 ·
kombi_kid ·
kafer70 ·
kafer70 ·
aussiebug ·
kombi_kid ·
70AutoStik ·
aussiebug ·
The 1300, 1500 and 1600 P&C use the same sized hole in the case - you can remove a set of 1300 clyinders and slip in the 1600 cylinders without altering the case.70AutoStik wrote:Beg to differ, aussiebug - I believe the 1300s had the same wall-thickness as the 1600s, except at the spigot and head areas. The "thin-wall" "thick-wall" argument traditionally refers to the early aftermarket 88&92mm kits, which continued the problem throughout the barrel. I'm not so sure the dodgy versions are still made (most P&Cs come from two factories these days, both from the same company.)
