my steering is really shakey and when i turn rite there is like a grinding noise eny ideas wat it could b?????????
56astro ·
Wheel bearings or steering box
IMHO
FaT_BuG ·
yeah i kinda had an idea it would b a wheel bearing
thx
Is the tyre rubbing on the inner guard... ist it a King n link front end or ball joint
If its yr wheel brgs they will be noisy all the time jack up the front of car and rotate wheels u will soon hear if its the brgs.
Are yr tie rods ball joints OK ??
70AutoStik ·
No, bearings will often only produce the noise when cornering; jack them up, yes, but try rocking the wheels to see if the bearings are loose. A little more info on what car it is might help - CVs can also produce noise when turning, but would not affect straight line that way, but it could be more than one thing.
FaT_BuG ·
big phat negative on that i absolutely stuffed both front tires and bent my sway bar so here comes 2 new front tires
