problems with my motor (1916)
https://forums.aussieveedubbers.com/threads/60835/problems-with-my-motor-1916
steve-89 ·
hey, been having some problems with my engine lately,
not sure wat seems to be the problem, but i have had several new exhausts put on it and either of the seem to make any difference, EG: when i got the motor i bought it off the forum from a guy in QLD, he said it was fine and also said it was a big boar.
the motor its self has 40 delloretto"s and a lumpy cam,
Irecently went out and spent $330.00 on an empi extractor and muffler kit i got it home and fitted it, When i started it, the motor backfires and sounds like the air cant get out,
Ialso bought an exhaust prior to that and got the same effect,
both systems are really noisy and sound really bad.
Is this something to do with my motor, like, is it out of tune or is it something to do with the exhaust pipe being to small in diameter,
can some one tell me wat the possibilitys are that it is something to do with my exhaust before i go out and blow big money on a custom one.
cheers steve
sounds more like you have a blocked pilet jet and fuel problems.
spark leads on the right plugs??
It doesnt sound like the exhaust
Worst case the motor would run without an exhaust - VERY loudly but "fairly" smoothly
[ Edited on 27-2-2007 by Bizarre ]
steve-89 ·
yeah the sparks and the leads are ok, it definetly got me puzzled.
craig- someone told me that it could be that ill have to check that out.
cheers boys
anything else it might be...
steve
lugnuts ·
Hey hows it goin,how long have you had this engine and was it running alright before and then not or has it always run like crap 😁
lugnuts ·
steve-89 wrote:hey, been having some problems with my engine lately,
cheers steve
STOP,please dont spend anymore money!!!!!!!:P
newoldmanx ·
didnt drop a washer or a nut into a port when you were taking the old system off did ya???
did you do a comp test b4/when you got the donk?
how long did the car you put the motor in sit for before the transplant??? could be stale/ dirty fuel
id start from scratch plugs, points, timing,rocker clearance, drain fuel bowls, clean and check dizzy cap, check carb linkage compression,etc all cheap and will only benefit motor anyway
FAST - fuel, air, spark, timing (valve and ignition)
If it has all these in the correct sequence, it will work!
newoldmanx ·
VWCOOL wrote:FAST - fuel, air, spark, timing (valve and ignition)
like he said ----i would add one more F.A.S.T.Compression:thumb
steve-89 ·
Lugnuts: what do you mean by that...?
thanks guys ill get that checked out asap.
steve
Yeah, maybe better said : FACT!
newoldmanx ·
lets say F.A.C.T.S ????????:thumb
koolkarmakombi ·
has it ever ran well in your hands?
steve-89 ·
KKK: yeah when i had a bigger exhaust on it
steve
sounds like it needs rejetting
free flowing exhausts often require fiddling with the jet sizes
especially the idle jets
-Joel
:thumb:thumb:
we got it aaaalllll covered now!
newoldmanx ·
:thumb:thumb:
something tell me you play a lot of scrabble
koolkarmakombi ·
Acronyms -R- Us
:thumb:thumb:
steve-89 ·
cheers for that guys..
steve
steve-89 ·
well after all problems i think the major one is now sorted..
this is my newly aquired exhaust. sweet hey....
well all that needs to be done is the jetting and the tuning.
thanks for everyones help.
steve
Gracey ·
Got anymore photo's of that exhaust, like looking up at it from underneath?
steve-89 ·
steve-89 ·
j pipes. and 4 into 2 connection. need any more just ask....
steve
Gracey ·
Thanks for the pics. Interesting exhaust system.
Let us know how it performs.
