WTB VIC Type 3 Pop-Outs Hinge Section
https://forums.aussieveedubbers.com/threads/60859/wtb-vic-type-3-pop-outs-hinge-section
65notch ·
Hi guys,
I'm after the pop-out hinges section off of the centre pillar of a squareback up to 71 so i can fit my pop-outs to my notch.
If anyone is wrecking a squareback or knows of someone who is in Vic then any help would be greatly appreciated.
Muz
1500S ·
Good pics showing the required missing bits from all OZ built Notches if popouts are to be fitted.
DH
GASBNR ·
my aussie built 65 had those 1500S
1500S ·
If any OZ built Notch has them in then they have been put in by some owner since 1965. ALL OZ built Notches had fixed rear quarter windows. Over the years there have been quite a few fitted which may lead to the thought that some came from the factory from 1964.
Our OZ built Type 3 was stripped of all the good gear including the paint coverage! The only paint on the inside of the rear guards was what blew through the gap between the guard and body hence the rust problem in that area.
DH
GASBNR ·
Sorry Dallas,
I ment the hinges for the pop outs where there and the screw threads in the 'C' posts not the pop outs themselves.
I fitted the pop outs.
OL
65notch ·
:bounceBUMP
bushed ·
i prob have it on the S notch in Bundy but needs ta pick up the whole car
400 km trip wid a trlr oho
can u wait a month??
if u in hurry maybe i can get a backload but it may be a few extra $$$
65notch ·
im happy to wait a month, my pop-outs are on snail mail from the US anyways so they'll be at least a month.
Let us know if you can get them
penguin ·
So if Aust built notchs didn't have these, do Clayton Vic built squares?
65notch ·
supposedly all squares have them so i would assume so
penguin ·
Sweet
thanks for that and good luck.
bushed ·
will be in touch 65 notcher.
65notch wrote:im happy to wait a month, my pop-outs are on snail mail from the US anyways so they'll be at least a month.
65notch ·
awesome, cheers bushed :thumb
avwboy ·
u2u a figure and ill cut them out of a wagon shell i use for mock up for a current project , and ill just mail em on down from syd .... mailing should be cheap as the pillar cuts wouldnt be very heavy
65notch ·
u2u sent avwboy
65notch ·
bump :bounce
1500S ·
For those who want to make their own bits for a popout conversion on any OZ built Notches, these are the mounting plates for the latches from 75mm x 75mm x 1.0mm plate.
Best to attach with about six 5/32" (4mm) pop rivets. The "nutsert" body will fit through the holes in the C pillar and the latch is held by standard M4 x 0.7 screws
Will post them on Sat for you Muz.
DH
[ Edited on 16/3/2007 by 1500S ]
GASBNR ·
Any type 3 stuff try Lindon 0409 573446
65notch ·
Thanks so much Dallas.
And i'll be sure to try Lindon about hinge sections, thanks empikg
type3disease ·
does this mean 73 sqares dont have the holes etc in the pillar as I saw "up to'71" mentioned.
1500S ·
The holes (slots) for the hinges are most likely there...not sure on that last model. The latches were held on the up to 71 Squares, in fact all Squares, with self tapper screws. Only the Notch had the 4mm metal thread screws holding them. Up to 71 Squares had popouts so the hinge bits are in the B pillar. If you find dead Squares up to the 71 year, cut the B pillar sections for the Notch mod.
DH
