central locking how did you instal yours?
https://forums.aussieveedubbers.com/threads/60876/central-locking-how-did-you-instal-yours
Learner ·
hey there,
i just got my central locking kit.... looked at it and my doors but i got no idea where to install the acurator. any pictures or advicce would be good. the only way i see it is to cut a small whole.
Takhoal ·
and what sort of vehicle are you trying to fit them to bud?
yeah more info what model and year would be a help
its much easier if you have a leter car with push button locks
Learner ·
keep on forgetting not every one knows my beetle :Phttp://forums.aussieveedubbers.com/images/smilies/tongue.gif
it's a 1969 1500 ....
the rod is behind the sheet metal of the door. do i have to cut it or is there an other way?
76camper ·
Spent a few hours trying to do it without cutting a hole on the first bus i did, its pretty much impossible because you will have to clamp on the clamp then twist it not really tight enough if you can twist it.
I just drilled two holes with the hole saw bit for a drill, that was on the first door because i didnt quite get the allignment right, 2nd door was only one small hole.
If you drill the hole/grind out a hole it makes installing the kit a breeze, took me about 15mins to install each actuator on my 2nd bus.
[ Edited on 1-3-2007 by 76camper ]
Learner ·
cool so i'm not making any mistakes putting holes in my doors. i actually started my first door. that was easy just wanted to make sure i wasn''t destroying my car for nothing.
KruizinKombi ·
It should be possible to keep the holes just large enough to fit the end of a screwdriver through, assuming you can reach around to hold the clamp in place while you do it up. That's how I did my kombi anyway.
one4 ·
Hey Learner
What brand of kit you using?
Interested in doing it to mine down the track.
Richard
Learner ·
i'm using mess accurator. they are swiss made and so far the best i have seen (pretty strong good for old mechanisms) check out a1electrics.com they have info on it. they also caree a power window kit for beetles.
sorry about the similar posts they were posted when the server was going through a hard time.
like i said i cut a whole through the door and all was installed in 20 mins. add another 20 mins and i had my
remote central locking kit installed. ( and i know nothing about auto electrics)
pretty proud of myself. the only problem is that i probably wired one of the remote console improperly as now i have no sound through my speakers. but it would be an easy fix
Learner ·
next step is to customise my door panels and slowly work my way through making kickpanels out of fiberglass.
