1800/ 2litre compatability
https://forums.aussieveedubbers.com/threads/609/1800-2litre-compatability
twobus ·
Does anyone know if I can put the top end of a 2 litre together with an 1800 bottom end together and is an auto 1800 able to be mated up to a manual (Type 3 IRS) gearbox.
Dasdubber ·
Not 100% sure but I know you can drop in a 2L bottom end into a 1.8 case, and use the 1.8 cam, lifters etc etc.
I am using an 1800 case with a 2L crank and rods, with the 1800 cam reground and 2L heads (with 1800 valves installed) for my type IV rebuild (to go into my 63 bug).
Bit confusing!!
Alan
Phil74Camper ·
Yes all Type 4 engines use the same case, so all the parts are interchangeable.
1800 engines use 93mm cylinders, while 2000cc engines use 94mm, so there's not much difference there. The 2-litre cylinders will slide right into your 1800 case.
The 2-litre crank has 5mm more stroke than the 1800, thanks to having offset-ground rod journals, but it will work perfectly in an 1800 case. You will have to use 2-litre rods of course.
Baja Wes ·
RE: the gearbox compatibility
You will obviously need a manual 1800 flywheel for your type 4 engine. The auto set-up on the engine won't work. Use the 1800 clutch and pressure plate. They will work with the type 3 throw-out bearing and starter.
The prob is the input shaft. The type 4 ones are longer. So you either need to put the longer type 4 input shaft in the type 3 gearbox, or put a bush in the type 4 flywheel for the shorter shaft
twobus ·
does anyone have anything to add!
[Edited on 24-9-2002 by twobus]
