i have 2 beetle semi auto gearboxes to choose from, $50 each, must sell, steve 0409475131
vwsteve ·
1 sold ,1 still available
vwsteve ·
bump
vwsteve ·
still got one
vwsteve ·
bump
ctefeh ·
Rexy,
Could help your cause if you could identify what type they are. Early ones have two temp senders on the bellhousing, a drain and a fill plug and a switch on the drivers side to swap the temp sender signals. Late ones only have a single temp sender and a fill plug.
Also the G/Box code is on the drivers side of the gear carrier housing stamped underneath a rib facing down towards the ground. That'll help as well.
