Hi all,
Just wondering what your thoughts are regarding rear disc brakes on Baja's and Buggies....
ratty 63 ·
https://forums.aussieveedubbers.com/threads/61138/rear-disc-brakes-on-off-road-vws
ratty 63 ·
11CAB ·
Baja Wes ·
aussiebaja ·
ratty 63 ·
Daves are going just fine - but most people don't drive like Dave so I thought I would see what normal people thought.... 😀11CAB wrote:Well how are Dave's going?
subibaja ·
LIFE IN THE LOW LANE ·
pete wood ·
MickH ·
pete wood ·
MickH ·
Yes..front and rear discs.NO they are not Ford units on the rear...pete wood wrote:have you got rear discs Mick?
pete wood ·
kroozzn63 ·
MickH ·
Most likely the Ford setup if you do it yourself.New blank discs can be drilled to any pattern and all the parts can be sought cheaply from the wreckers or the dump,where most of them end up. Pete,my rear setup are Shermans.kroozzn63 wrote:whats the best rear setup for a powerful motor road only and i want 4 stud vw ?
" sorry to jack the thread" oh and cheapest lol.
kroozzn63 ·
pete wood ·
ratbug ·
First up, you need the calipers and caliper brackets of the EA/EB rear end (others can also work). The Inside diameter hole of the caliper bracket doesnt fit over the VW bearing, so you have to get it machined out a few mm (something like 77 or 87mm can't quite remember). Then you need to redrill the four holes in the bracket that the VW bearing housing bolts through, people normally have it so the caliper hangs to the back end (bleeder nipple needs to face roughly upwards).kroozzn63 wrote:does anyone have details of what bits i need like ford ea falcon ? booster? etc?
dubbill ·
