aggri1 wrote:Hmm, bugger. The brakes on my bus are squealing as well, and I replaced the rotors and pads and rear wheel cylinders two years ago only. Wasn't very cheap. There's also a little pulsing during braking - that is usually a sign of worn discs isn't it?
I didn't think I was harsh on them! Machining discs already, grrr...
A.
The 'pulsing' during braking is either going to be warped discs, warped, damaged or mis-aligned calipers, leaking/seizing pistons or seals, or occasionally worn wheel bearings.
I'm not familiar with bus calipers, are they full-floating? If so disassemble and clean/lubricate the guide pins, checking for uneven wear or catching marks.
My guess is that would be the most likely culprit as your discs shouldn't have warped if they're only two years old, and you don't 'race' the brakes. It will also give you a chance to check the physical condition of the calipers.
Keep in mind that Holden recommend machining every 20,000 kms on their Commodore discs, maybe newly manufactured rotors are similar. Check with the rotor supplier for the manufacturers recommendation.
[ Edited on 17-3-2007 by sinecure ]
