4 stud Type 3 wheels
https://forums.aussieveedubbers.com/threads/61269/4-stud-type-3-wheels
jhp1 ·
Hi there is there any compatible solid steel wheels that will go on a type 3 square back? Im looking at trying to get them to look like Beetle solids.
Jase
baybuscamperkid ·
late beetle ones will fit but will have wrong offset
jhp1 ·
Will they be more positive or negative offset? ie in towards suspension or out toward gaurd lip?
*did* ·
do you mean you want rims like the 5 stud solid style? (ie: no holes?)
i have never seen 4 stud vw rims in solid style
Octa ·
What about filling in the holes of standard 4 bolt wheels? May look bad but may not.
Octa ·
Kind of like this:
Stock:
Holes filled in (bad pshop):
jhp1 ·
Yeah thats kinda what I want Get em powder coated. So welding them up is the only way to go by the sounds of it.
electricmonk ·
I would be worried about cooling the disk if you were going to be driving a lot. The disks don't seem to be that thick and being solid they may warp.
PHAT BUG ·
probably easier to convert it to wide 5, using early front and rear ends.
Rhett.
jhp1 ·
Gday Rhett Yeah I think I'll just stick with the 4 stud wheels and get em powder coated just looking for solid as they would look cleaner is all. Thanks all
Jase
