1916cc long block
https://forums.aussieveedubbers.com/threads/61339/1916cc-long-block
RodPenrose ·
I have another 1916cc engine that I can put together with all of these parts ;
used case , opened for 94mm , std tunnel $ 500
new 69mm cro-moly crank $ 400
new std conrods $ 105
new piston and cyl kit $ 417
new 043 hand ported heads , 40x35.5 stainless valves , dual springs $ 1067 pr
new engle cam of your choice $ 138
new std cam gear $ 33
new scat lifters $ 89
full set of bearings $ 110
german gasket kit with rear main seal $ 36
new std push rod tubes $ 32
used vw flywheel , now lightened and 8 dowelled $ 130
new cro-moly gland nut $ 55
new cro-moly pushrods $ 96
new cro-moly headstuds $ 115
new solid shimmed rockers with swivel feet $ 110
new bosch 009 dizzy $ 145
used crank install kit $ 45
new cam plug $ 3
new bearing dowells $ 10
new stage 1 kennedy pressure plate $ 215
new kennedy gold clutch disc $ 93
new bolt on rocker covers $ 67
bringing the total of this deal to $ 4011 and I will throw in a complete new exaught system to suit a beetle .This engine should be good for around the 100-110 hp mark. For an extra $ 50 you can up grade to a 74mm crank and take the capacity to 2054cc , thanks ROD , 02-42729920 .
what about the oil pump :jesus
