BRAND NEW CYLINDER HEADS
https://forums.aussieveedubbers.com/threads/61390/brand-new-cylinder-heads
RodPenrose ·
I now have a good supply of cylinder heads in stock to suit all type 1 based engines :
std replacement heads for all 1600cc engines , 043 factory Mexican heads , complete $ 484 pr
043 castings , 40mm x 35.5mm stainless valves , dual springs $ 717 pr
043 castings , 40mm x 35.5mm stainless valves , dual springs , hand ported , reshaped combustion chambers , 3 angle valve job , bored for 94mm $ 1067 pr
the same as above but with 42mm x 37.5mm $ 1245 pr
STREET ELIMINATORS , 42mm x 37.5mm dual springs to suit 94mm bore only $ 1250 pr
CNC ported oval/wedgeport heads , 42mm x 37.5mm , stainless single groove valves , dual springs with CNC combustion chambers in 94mm bore $ 1500 pr
SUPER FLOWS , with 43mm x 38mm stainless valves , dual vw springs , large cosworth style ports , CNC combustion chambers only in 94mm bore $ 1580 pr
All of the above heads are brand new and are in stock . I also have good used heads , rebuilt ex-racing ported heads and lots of other stuff , thanks ROD , 02-42729920
