kombi 1800 heads vs 2000 heads?
https://forums.aussieveedubbers.com/threads/61435/kombi-1800-heads-vs-2000-heads
mangrovejack38 ·
can anyone tell me if I can get better hp by putting mild cam in kombi 2ltr and swapping standard 2ltr heads to 1800 heads for bigger inlet valves ,or is it just better to stay with 2ltr heads?,cheers,Jack.
MickH ·
Go with the 1800 heads.I had 1800 heads on mine and noticed a big difference to the top end.Bottom end torque was down a bit though,but not really that noticable.
Schmoburger ·
Maybe try some higher compression pistons with the 1800 heads too... and/or a set of kadrons or IDF's.. depending upon ya budget and performance needs.
Either set of bigger carbs will easily get back ya low end torque, and the thing will go like clappers right through the rev range due to the non-standard heads.
And all this will benefit from said mild cam. 👍
[ Edited on 31-3-2007 by Schmoburger ]
mangrovejack38 ·
yep ,thought they would be better combination ,just wasnt sure ,will be in the market for som other carbs in very near future if anyone knows of any,webber site recommends dual 40 s .will see if I can find some.cheers,Jack.
