Bertie_64,
Ditch the 009. You have the dreaded flatspot that is prevelant with 009/34 Pict 3. Get an 034 SVDA or pillage a wreck for the standard distributor.
Failing that there are several mods you can make to your car to attempt to cure this.
First make sure your 009 is timed at 30 BTDC at 3500 rpm. Let the idle timing fall where it will. Do this after first determining where TDC is on your pulley, and checking that it is true.
Next up, adjust accel pump stroke to full volume.
www.vw-resource.com (Rob and Dave's website). You can check that your acc pump outlet nozzle is directed at the plate/throat junction (? if memory serves).
Go for a drive and see whether it's better or worse.
Next up is plugging the hole in the throttle plate. Can't remember the website but one does list all this. I'll see if I can dig up the site.
May as well give it a tune up as well. Rob and Dave's again.
Ctefeh
