I have a complete bottom end of an engine that will fit any type 1 , type 3 or early Kombi and will end up at 2054cc and consists of
used brazilian case , std tunnel , opened for 94mm
new balanced 74mm cro-moly crank
new balanced scat cro-moly conrods
used vw flywheel , now lightened and 8 dowelled , balanced
new cro-moly gland nut
new engle 120 cam and gear
new scat lifters
new main , rod and cam bearings
new cam plug
new rear main seal
new HD oil pump
all for the bargain price of $ 1995 . I can also assemble this deal for an extra $ 200 . thanks ROD , 02-42729920........For those people that have inquired about this engine , I can add the following parts to complete this deal ,
new 94mm piston/cyl kit
new 043 heads 40 x 35.5 stainless valves , dual springs
new cro-moly pushrods
new std pushrod tubes
new solid shimmed rockers
new swivel feet adjusters
new bolt on rocker covers
new cro-moly head stud kit
for an extra $ 1590 bringing the total of this engine to $ 3585 + $ 300 for complete assembly . thanks ROD.
[ Edited on 4/4/2007 by RodPenrose ]
RodPenrose ·
