Could any one please tell me how to identify the year and model of my beetle.
cheers Liz.
Sulla ·
What does your registration paper say? Tell us more about it.
Round headlights or oval shaped?
More info required Liz.
geneliz ·
I bought this car unregisted it has been sitting for the last 10years. It looks similar to my 64 but I need to know how can I tell the difference between years or models and is there any vin plates or other plates on the body that can tell me.
liz
Sulla ·
Hi again Liz. The chassis number for that era is generally located under the rear seat in the middle on the tunnel just in front of the oval shaped cover plate. The numbers are sometimes worn and a bit unclear so just wet the area and it may highlight the chassis number. You can also have a look behind the spare tyre as there is sometimes a "manufactuerrs plate" located there. Once you have the chassis number you can research on the web or post the number here.
Does it have a Pope's nose or the wider number plate light? It is 6 volt or 12v?
[ Edited on 9/4/2007 by Sulla ]
geneliz ·
I have found a number under the back seat now where abouts on the next do I do a search to find the information I am chasing.
greedy53 ·
post the numbers up here someone will have the answers including me and if ya post the engine number i'll tell ya the model came from
Whats the chassis number tell us here and we will advise
what date and month is on the back of the speedo
geneliz ·
The number is 197759896.
liz
67 model :thumb
-Joel
the number indicates its a 1967 model
1 = Beetle
9 = Made in aussie
7 = 1967
It should have rear seat belts mount points behind the rear side windows ??? and 2 point mounted sunvisors
Whats the back of the speedo say
geneliz ·
On the back of the speedo it is stamped with 967. So thank you for helping me find this info.
