porsche 944 steel irs arms with V-Force drive flange to suit pcd
5x114.5 ford,nissan,honda.
$350+frieght
Also comes with adjustable spring plates
seller malcolm
location vic ,werribee sth
phone 0397421864
malcolm ·
bump these have the porsche CV drive flange and axles
555bug ·
Does this come with the drive shafts?
free bump 🙂
malcolm ·
I don,t have the drive shafts due to the box being moved forward 75mm.
I can get the drive shafts at a good price.
so it has the springplates with the ecentric in it ?
malcolm ·
yes 20+/- in height
seagull ·
I think I have the factory drive shafts here
Lenth ? tell me & I will check
If your using these arms on a bug you can use stock drive shafts, but fit a Kombi CV to them on the trailing arm end and if you can get modified gearbox output shafts you can run a Kombi CV there as well.
