I have 5 only @ this price . These are 100% new using no second hand , used or reconditioned parts . ALL PARTS ARE BRAND NEW and include ;
magnesium or aluminium case opened for larger bore
cro-moly counterweighted , 8 dowelled crank
std conrods
lightened 8 dowelled flywheel
94mm piston/cyl kit
043 heads with 40 x 35.5mm stainless valves , dual springs
std pushrods
std pushrod tubes
all bearings
engle w110 cam
std aluminium cam gear
solid shimed rockers
swivel feet adjusters
oil pump with filter
aluminium degree pulley
chrome pulley nut
cro-moly gland nut
german gasket set
rear main seal
flywheel shims
crank install kit
case install kit
bearing dowells
dizzy drive with shims
aluminium bolt on rocker covers
all for the bargain price of $ 3945 . Assembly will be an extra $ 400
RodPenrose ·
