6v to 12v conv - battery?
https://forums.aussieveedubbers.com/threads/61801/6v-to-12v-conv-battery
sean68 ·
I've just converted my 65 beetle from 6v to 12v and i am wondering which battery is used....a 6v battery or 12v battery?
None of the articles i've read say anything about running a 12v battery
sean
pod ·
12volt :thumb
*did* ·
a 12 volt conversion is just that.. converting everything to 12v!
12v battery included 🙂
(and you may run voltage droppers for some items that cannot be converted)
[ Edited on 14/4/07 by *did* ]
sean68 ·
Thanks for the replies
the only thing i didn't convert is the starter and solenoid as the 12v solenoid won't fit my starter....can i add a voltage dropper to this?
pod ·
i just use the 6 volt starter but then again my one is not a daily driver
*did* ·
sean68 wrote:Thanks for the replies
voltage dropper probably wouldn't be able to handle the current.
i think people just run 12v through the 6v starter, it just spins faster. not sure about the solenoid.
can anyone confirm?
sean68 ·
thanks again
the thing is when i tried the 12v battery the starter didn't seem to like it but when i tried the 6v battery it started straight up
i'm going to try the 12v again tomorrow after a charge tonight and see how it goes
warb ·
i got a 58 with 12v... and a 6v starter, spins up and kicks over every time, just don't hold it too long... if having starting probs give the starter a rest every now and again..
when u say "the starter didnt seem to like it" what to you mean exactly?.
MickH ·
Starter should work fine on 12 volts. I had one on a daily for 5 years and had no problems,just spun faster !!
sean68 ·
Ok
12v battery working fine now 👍.....don't know what was going on with the starter
now i gotta find out why both front blinkers aren't working.....rear ones working fine
the joys of working with electrics
