fuel rising fuel regulater
https://forums.aussieveedubbers.com/threads/61828/fuel-rising-fuel-regulater
greedy53 ·
i have a polished fuel rising regulater that i aquired for the rod's supergharger and don't need it it's polished aluminiun with all fittings goes to 140 lbs so good for fuel injection turbo or supercharging really nice bit of kit
steve rae
camden 2570
0434388795
$100.00
[ Edited on 15-4-2007 by greedy53 ]
Dasdubber ·
I steve, I am interested - however do you know the brand, and/or have any pics? I need to figure out mounting location etc.
alan
greedy53 ·
i/ll get some happy snaps tuesday and have them up that night
TEM DESCRIPTION
Part No: FPR-1R
Item Name:
Universal Adjustable Fuel Pressure Regulator -
For TURBOCHARGER, SUPERCHARGER and N/A cars !!!
Size:
Description: Our Universal Adjustable Fuel Pressure Regulator can be adjusted manually. High-precision body effectively improves fuel supply pressure and enhances acceleration and re-acceleration power.
To maintain precise fuel metering, the vacuum modulated pressure regulator maintains a constant pressure differential across the fuel injector. This means that fuel rail pressure will always be at a constant value above mainfold absolute pressure.
Low intake manifold pressure (slow down for example) pulls on the diaphragm decreasing spring pressure. This allows more fuel to return to the fuel tank deceasing pressure in the fuel rail. Opening the throttle (speeding for example) increases manifold pressure. With less vacuum on the diaphragm spring pressure will incease restricting fuel flow to the fuel tank. This incease pressure in the fuel rail.
greedy53 ·
finally some happy snaps
Dasdubber ·
Hey mate, thanks for the details and pics....I unfortunately might have to hold off for now to both:
A) do some more research, and
B) save some more money!
Good luck with the sale, hope it goes to a good home 🙂
greedy53 ·
no worries
reub ·
I'm running one that looks identical to this one on my purple bug.
Mine's made by OBX and came in a no name box the same.
Mine works fine....
greedy53 ·
yep sounds about right this came in a plain white box too i found out that i didn't need this type so off it goes cost a bit more than what i'm asking thought it would go a bit quicker silly me
