Why do people use the short axle swingaxle setups for drags?
https://forums.aussieveedubbers.com/threads/61945/why-do-people-use-the-short-axle-swingaxle-setups-for-drags
I'm assuming the shorter axles are stronger ?
Less overall weight ?
Any other reasons..........
[ Edited on 20-4-07 by Craig Torrens ]
jakjones ·
to fit the fatty tyres
I originally thought that..............but that is controlled by the rim offset?
Dak-A-Tak ·
Craig ! for me it's Tyre under car more but I have raced the last 16years with long axles on my yellow car (sway-a-way )
I have never broken a axle but wheels choice is all ways difficult for volkswagens (off sets)and then most times you have to put on fat mudguards on.
Most drag or tuff street bugs don't need very wide slicks
on back (6 or 7 inch fine )
I have never had a handling problem anywhere but I think it's more the width of front end to do with that! ( equal back and front wheel centre's )
I'd better stop there! Craig your car doesn't matter.
Did you get my u2u (sec one ) about front shocks
Peter P
Didn't get any u2u's:cry
Boostn ·
You can tune the rear end wheel spin by adjusting the height. More or less tyre.
Helps with not wasting energy wheel standing or breaking trannys. Or you can tune more tyre into it if you go to a crappy track. Plus NO cv problems.
thanks for that............................I was wanting to find out why the narrower swingaxle (1200) apposed to the wider (1500).
Just want to make sure I'm building the right gearbox combo.
