help needed regestration woes
https://forums.aussieveedubbers.com/threads/61958/help-needed-regestration-woes
CAFFINEPUSHERMAN 路
guys finally passed roadworthy in victoria for my 60 ghia ,i went to vic roads yesterday to book in for regestration when i was asked for the previous regestration of the vehicle .now the problem with that is the guy i purchased it from purchased it in the early 80's as a project with no rego the guy he got it off also had it as a project so she has been off the road probably since the late 70's .with no rego number i got no reg ,i think the car may have come from WA as i found WA newspapers stuffed in the heater channels has anyone got a solution for me .or perhaps someone has some old plates off a 59/60/61 beetle from tas or wa or vic that havent been on th road for years that i could use to get around the problem the car is a genuine RHD Aust delivered ghia its not stolen just fell out of the loop for 30+ years many thanks chris 0413840010
CAFFINEPUSHERMAN 路
the wa and tas references are because they are not connected to the vicroads system . I have pulled three cars from paddocks and had no problem registering them over the years ,bit scared about the T model Ford hot rod i am just about to purchase馃槵
h 路
isnt that just BS.. geeze its been off the road for for umpteen years you would think common sence would prevail.. feel for ya.. hope it all works out fine soon..
blutopless2 路
i take it you explained how long its been off the road etc??
i would've thought that they could check back with the chassis and engine numbers etc.
CAFFINEPUSHERMAN 路
blutopless2 wrote:i take it you explained how long its been off the road etc??
had no engine so i put a new one in there is no record of the chassis number .if my memory serves me right they only used to put the engine number on the old transfer sytle rego labels maybe one of the older members could help with this one
amazeer 路
geez when I regod my fastback in NSW all I had to do was sign a stat dec saying I bought it.
baybuscamperkid 路
is there any plate to say that it is aus delivered? ring vicroads, there may well be (should be) a limit on the number of years back you have to go to find a rego - ie if it hasnt been on the road for 30 years they probably dont have the original info anymore so you shouldnt have to find it. surely there is some sort of ID plate on the car?
greedy53 路
yep give vic roads a call and get the name of the joker telling you the info so you can quote his name when doing business i have had trouble before with wrong info given so now i take down all names so a rhone call can fix any and maney probs
Hertz 路
I think you can fill in a stat dec' mate, and use that. Talk to Golde60 as he had the same dramas with his rag from tassie.
VWCOOL 路
Yeah, there shouldn't be any dramas with getting rego - if it's not 'in' the system, so what? As long as it's not 'rebirthed' and meets safety regs, it should go 'in' easily...? It does in NSW...
GASBNR 路
Gotta say I heard different stories from VICROADS (what greedy said)
They just can't get there shit together
h 路
yeah qld a bit the same specially if your doin a baja or alike..
this one time at... i was regoing my 71 twin cab ute, when the 'lady at the counter' came out to verify the numbers she was impressed how i cut down a 'regular kombi' into a ute style..
needless to say her next comment was 'wheres the blue plate and engineers report' before i could get it regoed.. :duh
after assuring the dear that it was a factory item and then the rest of the staff came to my way of thinking it got regoed.. phew..
anyway the story seems the same which ever state you go in..
helbus 路
Yet when an acquaintance of mine took his wildly modified, non-engineered car to Vicroads, he took it on a trailer because it was too wild to drive, and because he actually used the original engine block that had the engine number that was correct for the chassis, and he had the original rego papers from about 20 years ago. They checked the numbers, stamped the papers, and he was re-rego'ed. The car wouldn't have passed engineers inspection let alone should have been that easy.
empi 路
Ring Vic roads ask what the go is in this situation , i think you will get a diffrent story. Vic roads only keep refrence of rego for 7 years. i will look see if i have some plates for you.
65busser 路
I think you only need a receipt from the seller. They like to know the previous reg 'cos they simply pull the car up and re-register. Otherwise they have to start again, but I don't think it'll slow you down by not having it. Happens all the time.
CAFFINEPUSHERMAN 路
this woman at vicroads kept me waitng for half an hour ,when they put my chassis number in the computer nothing came up for the number she was saying that it was an import which i know it isnt .i will try another branch tommorrow
65busser 路
Yeah nothing came up 'cos they ditched all their old records...dumb b'tards. She's just assuming cos there's no record it's an import. Really you just gotta keep pushing them to think. Ask for the supervisor cos they're the only ones who'll think it through.
PrettyBlueBug 路
When I got a couple of daily driving permit-things from VicRoads for my Fasty I had no dramas. The chassis number was listed yet the engine number wasn't in their system... and the old S.A plate still on the car didn't come up with anything either, but since this shows the thing had been registered however long ago they were fine about it. They also said I shouldn't have a prob when time comes to rego as I have a receipt for buying the car. guess it could be a different story when it comes to crunch time. :duh
Hope it all gets worked out!
helbus 路
Vicroads had no computer before 1978 I was told, so if it went out of rego before then, It is basically gone from any system they have, gone almost forever.
AOMC http://www.aomc.asn.au/eng&regrecords.htm have all of the old manual card records from Vicroads before 1978, but there are millions, but if you have original rego number, they can look up your original data card and you can get some information excepting any previous owners names or addresses. Cost is $55
Post 1978, If you don't have an original rego number or chassis number, yet again they are lost.
Push 'em hard, you pay, and you deserve service for that payment.
VWCOOL 路
compayo wrote:Yet when an acquaintance of mine took his wildly modified, non-engineered car to Vicroads, he took it on a trailer because it was too wild to drive, and because he actually used the original engine block that had the engine number that was correct for the chassis, and he had the original rego papers from about 20 years ago. They checked the numbers, stamped the papers, and he was re-rego'ed. The car wouldn't have passed engineers inspection let alone should have been that easy.
lol... let's hope he doesn't crash. Unless he likes jail food!
helbus 路
Sad thing is, it is basically a trailer queen, and doesn't see roads, but he still got it rego'ed?
242 路
Have dealt with this same issue with Vic roads a couple times now. Keap pushing and get them to let you sign a stat dec..
beerdoc 路
Come on pusher
Have a look in the mirror
Would you trust that guy:kiss
DID you make an appointment? they like that
h 路
so how did you go with the evil vic roads then..
CAFFINEPUSHERMAN 路
still no luck try again today
CAFFINEPUSHERMAN 路
good news went back to vicroads today got a really noice bird who was polite and helpful unlike the bitter mole i got last week she even wrote me a letter and got her manager out to help when she was out of her depth i was allowed to make my booking one step closer 5th of may looks like the day
rose 路
Good Luck! I'm glad I don't live in VIC. That's just crazy all I had to do up here was go get a blue slip and the blue slip guy had a stat dec form for me to sign to easy.
68AutoBug 路
I was lucky...
the rego plates were stil on the car...
and i had the rego papers
even though the car had not been regoed for over 10 years....
Best of luck
greenman 路
Must have been your persuasive deep voice, olive skin and brown eyes. Well done!!
OZ Towdster 路
Makes you wonder how Bob Hatfield got that crazy 55 Chev Registered with 3000 hp V12 Merlin a couple of years ago ,must have had the old plates NOT
CAFFINEPUSHERMAN 路
cal68 wrote:Must have been your persuasive deep voice, olive skin and brown eyes. Well done!!
that old chestnut only works on your waiting staff:P:P
you gotta love my old guinie charm
