EJ20 Head Gasket problem
https://forums.aussieveedubbers.com/threads/61977/ej20-head-gasket-problem
ElusiveStranger ·
I wonder if anyone can identify this gasket please. It's meant to be a 97-98 EJ20 2l NA engine. (I've even measured the bore and stroke - 2l)
I have been supplied with gaskets but they do not match.
Here's my head:
Here's the new gasket on the head but shifted down to show the mismatch
[ Edited on 21-4-2007 by ElusiveStranger ]
pete wood ·
I suspect, your heads are earlier. Take the gasket back and swap it.
ElusiveStranger ·
Pete,
Could you please be a bit more specific please? Earlier than 'what'?
I've got a 'buggers muddle' going on here!
(might have to go to the Subaru dealers on Monday [cringes at expense]
pete wood ·
what I was saying is I think you've got a motor that is pre 97-8. wreckers (car brakers) are often a bit optimistic about the age of motors they sell. I have what was spose to be an aussie spec 99 outback 2.5l. I now know it's more like a 95-7 2.5l import motor from Japan. Unless you have the chassis no of the specific car it came from there is no real way to check than by comparing parts. Subaru has so many different variations on their motors that it's a real pain to try and figure things out sometimes. take your old headgasket to the subaru dealer. ask him to pull them out until you find the right one. when he realises you are serious he will help hopefully. when you get the right one, record the serial no somewhere safe for the future. 😉
btw, how did you blow your head gasket?
ElusiveStranger ·
Cheers for the reply Pete.
Will be going to the main dealer tomorrow. When I asked them before about gaskets they quoted me approx £200 for a full engine set, that's around 480 ASD. Was told they wouldn't supply just the head gaskets.
I've asked on a Subaru forum and a few people recommended Cometic and a few other brands. I got the replacements from E-bay at a very reasonable price (well it would have been reasonable if they'd fitted)
I only needed head gaskets 🙁
Gotta say Scoobies can be a right PITA if you don't have a chassis number. I thought having an engine number would be fine - couldn't have been so wrong!
By the look of the gasket that failed it was incorrectly fitted and the metal part of the sump oil return moved, creating a weak point.
Here's a picture of the failure:
ricola ·
Another way of helping age an engine is to check the date clock on any plastic moulded parts. An easy one is inside the oil filler cap..
Rich
ElusiveStranger ·
ricola wrote:Another way of helping age an engine is to check the date clock on any plastic moulded parts. An easy one is inside the oil filler cap..
Rich
hehe, mine range from 94 to 98. Prob with dated stuff is it may have been replaced. Scooby dealer did date my ECU serial number to 97 though
I know it's low mileage though as there's still honing marks in the bores
Fingers crossed for tomorrow!
[ Edited on 22-4-2007 by ElusiveStranger ]
seagull ·
I think the gaskets you got were for a quad cam
ElusiveStranger ·
seagull wrote:I think the gaskets you got were for a quad cam
Does my head look like the ones you have seen, Seagull?
I did tell them it was a SOHC EJ20
