One owner till 2000, service record shows total of all 83000 miles.
Speedwell BRMs by gimp, researching this combination...
CB 1955 D.I.ENG KIT 76X90.5, 5.400" SUPER RACE RODS, stroker "B" pistons
CB 044 SPECIAL with 40 x 35.5mm S/S valves, Single Hi-Rev Springs
CB Dual 44 IDF Kit, T-3 Dual Port
CB 90.5 TOTAL SEAL PRO SET
Webcam Billet Lifters
Webcam #163 grind, 0.422" lift, 284 deg duration, 249 @.050
bugpack MINI SUMP KIT
full flow filter kit with plugged 26mm pump
GENUINE 911 ADJUSTERS
(Aircooled.Net) SUPER-HD Aluminum Pushrods
CB HIGH PERF. ROCKER SHAFTS
S&S tuned length 1-1/2" ceramic coated merged Type 3 header
Kennedy Stage 1 1700lbs 200mm Clutch pressure plate
CB Lightweight Forged Chromoly Flywheel
(Aircooled.Net) Bosch SVDA (SDDA) Distributor, with vacuum advance
COMPUFIRE electronic ignition module
bus914 ·
