FOR SALE - 1961-1967 Split Window Kombi Reduction Hub Gearbox $400.00
https://forums.aussieveedubbers.com/threads/62088/for-sale-1961-1967-split-window-kombi-reduction-hub-gearbox-40000
bluescorpion ·
split window kombi reduction hub gearbox - complete from drum to drum in working order $400.00 ph. 0438177776 located at Bagdad in Tasmania but will freight at buyers expence.
[ Edited on 27-4-2007 by bluescorpion ]
[ Edited on 29-4-2007 by bluescorpion ]
[ Edited on 1-5-2007 by bluescorpion ]
warb ·
ill buy the nose cone if you split it up..
bushed ·
what hp nose u want
i got 2-3 think 40 hlp or 36
57 Panel ·
What year bus is it out of.
Adam......
bluescorpion ·
unsure - somewhere late fifties to mid sixties (they all should be the same) .
bluescorpion ·
What are reduction hub boxes worth ? ? ?
bushed ·
they are not the same as 36 hp was a split case and no synchro on first gear mostly to 1960 as beetles
40 hp is a tunnell case and started aorund 61 as 40 hp beetles.
36 boxes have a meta bracket bolted onto carry the clutch conduit
hey also have smaller brakes.
40 hp has the bracket as part of he box case and bigger brakes (prob)
B
email me for more info or pics
bushed ·
so yeah the red'n boxes may be same? but synchro on first in 40 hp
later ca 64? with 1500 engines coming in there was a big axlebox nut introed ...bigger/ stronger
so the red'n boxes and all else would be stronger i guess.
how much ? depends on condition and location
Melb has stock qld has not and big distances to ship !!!!!
seen emm for $150 to $600
Rural Baja ·
What happened to the split?
bluescorpion ·
This is NOT the 36hp split type pre 1960 gearbox with no syncro on first gear. THIS GEARBOX IS the 40 hp tunnel type (with syncro on first gear)gearbox that started around 1961 to 1967. It has the cast type clutch conduit bracket as part of the gearbox & it has the bigger type brakes. Hope this helps ! cheers- Trent.
Rural Baja ·
And the kombi whart happened to her?
bluescorpion ·
EMPI - keep watching as I WILL have an ORIGINAL unrestored Splitty up for sale in the coming few weeks ! Totally Complete. Not saying anymore about it at this time !
Rural Baja ·
Ooh how much. Very cheap? Can i have first Dibs!
bushed ·
u tassie devils u!!
bluescorpion ·
still 4 sale
