heads
https://forums.aussieveedubbers.com/threads/62107/heads
aussiebaja ·
hi guys can you please tell me if 1300 heads will fit on a 1200 donk ,,,thanx
dangerous ·
Yes they bolt on,
but you may(or may not!) need a head stud change on one or two? (cant quite remember).
You WILL need to change the mainfold though, since the 1300 one is too wide.
I cut mine and re-welded it, but yoi might like to just cut and use hose and clamps,
in which case you may need to brace the manifold with a piece of flat stick-metal.
Gunna put on some 83mm barrels too?!
aussiebaja ·
got some spare ones ,there was some 1300 heads on ebay cheap and i was just thinkin if i got them shaved down they might work better ,they were dual ports as well
dangerous ·
If dual ports then you WILL need to change the head studs.
You can just shorten the ends of the dual port mainifold where it goes into the boots.
aussiebaja ·
thanx man
