subaru twin turbo motor and modified box
https://forums.aussieveedubbers.com/threads/62109/subaru-twin-turbo-motor-and-modified-box
boof2332 ·
I am geting more interest on the 914 in stock form so I might pull the ej20tt and the modified subaru 5 speed and sell them. It is a 96 gt liberty motor that was bench run prior to purchase with about 70k on it, they are set up as a midmount and come with a full harness, computer and performance clutch. Also custom box and engine mounts and shifter linkage set up.Perfect for a spyder formula v or kombi mid mount conversion....or a bug if creative. $2000 ono
matt 0416 115 993
seagull ·
? please Matt
metal head gaskets ?
what injectors ?
gear box code ?
cheers seagull
boof2332 ·
Ill check it out and let you know..
How did you go with modifying the sport matic porsche box?
Matt
tinman ·
Quick question.
How would one of these engines go in an 'AUTO' 77 Microbus?
Not sure how the 2lt auto gearbox would handle the power from the ej20tt engine.
I've been thinking about a Subaru conversion for the power and fuel milage for a while now but have been worried about the auto gearbox.
seagull ·
The mods will work , I have the box here on the shelf just need to get the out put shaft machined
seagull ·
tinman wrote:Quick question.
very well , the TT motor makes very good power down low under 3K
the auto box would be very good with this combo , these are a very stock gear box with a small up grade to the clutch pack ( adding one clutch & a cooler ) will last for ever
