link pin rebuild kit / drop spindels get a deal
https://forums.aussieveedubbers.com/threads/62124/link-pin-rebuild-kit-drop-spindels-get-a-deal
seagull ·
seagull Neil
Perth wa
my quit list of of items is as follows
weld in adjusters
Now $50.00
vw fly wheel 200mm c/w EJ 16 / EJ 18 / EJ20 / EJ25 subaru center
I can provide you with the adapter plate template , so you can make your own $300.00
The dragon gear box is listed in this section as well .
neg on price , get your self a deal on this !
$1500.00 ( dam cheap box )
0407074141
[ Edited on 12-5-07 by seagull ]
[ Edited on 15-5-07 by seagull ]
[ Edited on 17-5-07 by seagull ]
[ Edited on 27-5-07 by seagull ]
[ Edited on 2-6-07 by seagull ]
[ Edited on 6-6-07 by seagull ]
seagull ·
TAKING OFFERS WITH CASH IN HAND
seagull ·
bump to the top
seagull ·
Keen to move these items on
seagull ·
bump for these bits
seagull ·
prices have been adjusted 12/05/07
seagull ·
up you go
wiseoldub ·
what? looking at those drop spindles but .......i don't get it
let me know if things change
cheers josh
seagull ·
Things do change
wiseoldub ·
i've got a narrowed adjustable k&l beam with discs and i want to drop spindle it. what do i need to look for to ensure that your kit will fit? and is your set just spindles or are you selling the discs too?
cheers josh
seagull ·
you need to look no further as this a king & link pin drop spindle kit for disk brakes ( no disks included ) so thats spindles c/w new link pin rebuild kit all in a box never fitted ( new )
my number is 0407074141
humpty ·
wiseoldub wrote:i've got a narrowed adjustable k&l beam with discs and i want to drop spindle it......
Josh.... Are your discs OG or aftermarket?..... Neil's spindles will only run OG VW discs (130PCD) and calipers or aftermarket discs designed to use balljoint bearings........ Some aftermarket 'wide5' disc (205PCD) brake kits are made to fit OG LP spindles and will not work on drop spindles as they use 'slider' style calipers.....
Just a word of warning....
And the price is bloody good by the way....
seagull ·
these need to go .I have droped the price to move them
humpty ·
I'll grab the beam Neil.... Will call you later this week mate....
wiseoldub ·
sorry, been busy. they won't fit mine and thanks for the help! looks like adjusters will do for now! nearly got myself some expensive paperweights then!
cheers josh
seagull ·
bump
humpty ·
wiseoldub wrote:sorry, been busy. they won't fit mine and thanks for the help! looks like adjusters will do for now! nearly got myself some expensive paperweights then!
cheers josh
Don't be so hasty Josh.... What have you got?.... There is more than one way to make it work..... I have fitted OG TIII discs to a LP spindle in the past.... Just need to know what you have first.... Im currently putting a 4 wheel disc brake package together for Reuben that runs 205PCD and drop spindles (Same as on my car)... Just need more info from you to confirm your needs....
wiseoldub ·
mine is a 10 year old kit made by vvws that i got second hand, it has porsche stud pattern and beetle 4 by the looks of things. i got told it needs late beetle bearings today. by the way, can i put a duel circuit master cylinder on my 67 bug? how?
all help appreciated!
cheers josh
humpty ·
wiseoldub wrote:mine is a 10 year old kit made by vvws that i got second hand, it has porsche stud pattern and beetle 4 by the looks of things. i got told it needs late beetle bearings today. by the way, can i put a duel circuit master cylinder on my 67 bug? how?
cheers josh
Well it sounds like Neils drop spindles will work then.... Sounds like a kit I made for my LP bug back in the early 90's.... Does your brakes use VW calipers too?.... A dual circuit MS will bolt right on.... You will need to source new hardlines (I pull them off VW wrecks) for the front brakes I think (its been a while since I've done one!!), new soft line for the reservoir and a late model dual circuit reservoir to suit (again, pulled from a wreck).... And if you haven't done it for a while, you should replace the brake lines to the calipers too while your there...
wiseoldub ·
excellent, i gotta get out of work more and into the tools again!! cheers for the help! i might just get those spindles after all!
seagull ·
Simon , I would like to give ebay a go on these please .can you give me a call when your free .
The gear box as well
seagull ·
bummmmmmp
Tonz Magonz ·
seagull,Are these the same brand as humpty is selling.? What would the post cost to postcode 3179 Victoria.? Regards Tony
seagull ·
Yes Tony they are
Postage would be $25.00
humpty ·
Sorry Neil.... I should have waited until you had moved yours.... Grab these Tony.... A much better deal.... Neil's got the rebuild kits there too....
seagull ·
Thats ok Simon
& bring some beer as I have ran out 🙂
humpty ·
Will do mate..... 5ish good for you?
Tonz Magonz ·
I will take the drop spindles and rebuild kits thanks Neil.These should work well on my 61 ghia.( p.s.thanks also Simon for the feedback)
Please u2u me your preferred payment method.
Regards Tony 0412370071
[ Edited on 4/6/2007 by Ratmuller ]
Tonz Magonz ·
Neil,
Received the drop spindles and rebuild kit today.Thanks for moving them so quickly ;only problem now is, I cant fit them untill I get my narrowed beam built and installed.After the Heathcote VWCV Drag meeting on the weekend I'm motivated to build the Ghia into a steet/strip car and the drop spindles should compliment the "look" nicely.
Cheers Tony
seagull ·
Thanks for the feed back , Neil
