hey guys
im after a late beetle accelerator rod, like 68 onwards.
like in the pic running thru the pedal cluster.
thanks
regards
sam
Adsman ·
I have one out on the property in a 72 beetle. u2u me if you are still interested and give me an indication on what you will pay for item or whole pedal assembly. As I have to drive out and get them.
bushed ·
they are not much diff to 6volters Sam
same length
same diameter
can do what u ask iff u push me as i can change my 72 over for U
11CAB ·
bushed wrote:they are not much diff to 6volters Sam
same length
same diameter
They are vastly different
bushed ·
i have emm on the bench
so what is vastly
the acc pedal spacing if its only the small rod
pls explaine
11CAB ·
This is an early one.....it is angled differently and has a hole in the end that I've put a bolt through.
bushed ·
yeah mine has no roller on it atmo
so without that its not too vast
but Sam is asking for the ROD
11CAB ·
Can you not see the difference between the rods in the two pics??
bushed ·
same length
same diameter
also end up the same height
and
put a sock on that foot
gettin colde.
11CAB ·
The late rod has the roller and is not attached to the pedal
The early rod has a linkage that is attached to the pedal
