shocks
https://forums.aussieveedubbers.com/threads/62246/shocks
aussiebaja ·
hey guys ,just wonderin what sort of shocks would do the best for my 62 baja ,something to help lift but not rough as guts if at all possible ,,,i had a set of coil overs lined up here but the guy never got back too me so he can keep em,
Shocks don't help 'lift' - that's the role of your torsion bars and tyres - but Cofap Gas Charged are good little units for not much $
aussiebaja ·
so youve never changed a set of shockies and had the new ones lift the car a little higher ,like an inch or so,especially if there heavy duty gas
13bwagon ·
na vw stock shocks don't have any expanding force like new car so they wont have any more like you can go the coil overs again would be the cheap job lift kit would be good with a raised front beam but thats some big bux
stacy b wrote:so youve never changed a set of shockies and had the new ones lift the car a little higher ,like an inch or so,especially if there heavy duty gas
yeah, by about 10mm - but I'd hardly call that lift
13bwagon ·
and even other cars when you put new shock in and let it down they mght be a little higher
then when you drive it it should sit the same
im going to run air shocks on the rear as i have seen a t3 wagon with the and they work great when they where loaded
aussiebaja ·
i thought about running air shocks front and back on my baja
13bwagon ·
i think they are the cheapest way to go and adjustable!
64vwmark ·
I reckon that you get a beam adjuster fitted on the front (or you can just cut and turn the beam) and adjust the preload on you rear torsion bars.
aussiebaja ·
yeah ive looked at that ,but there,s a bit of work involved ,not that im lazy it just worries me to do the back ones ,
13bwagon ·
what do you mean back one?
aussiebaja ·
you can undo each rear spring plate and rotate them down one tooth to raise the height
64vwmark ·
That's what I was talking about....
13bwagon ·
stacy b wrote:yeah ive looked at that ,but there,s a bit of work involved ,not that im lazy it just worries me to do the back ones ,
what a nut job the back ones are the easy part on t1
aussiebaja ·
oh thanx
13bwagon ·
your welcome buddy :party
