Not long ago I had to replace my DRIVERS SIDE swing axel, (it kept developing a an oil leek, I was told the shaft was probably bent), I replaced it with a 1500 shaft. While doing this I lowerd the type 3.
Anyway about week down the track I notice a flapping noise, the next morning the tyre is flat and has a doughnut shaped hole (exposing the metal wire) on the tyre. Replace tyre, then that side starts rubbing the guard on left hand corners only, (it's always under the guard now its lowerd) and car starts to "roam" at higher speeds, I check the wheel and it has some movement (wobble) with the drum but doesn't seem to be in the axel.
I'm about to pull it apart and try to find out the probleme but don't know what I'm looking for.
MY68VW ·
