Draining a T3
https://forums.aussieveedubbers.com/threads/62503/draining-a-t3
as it says - how do you drain the fluid from a T3
Is there a drain plug or do you undo one of the hoses somewhere??
Barry
Menangler ·
What fluid?
engine oil, auto fluid, geabox oil, brake fluid. power steer fluid or coolant.
Coolant I suspect, undo one of the hoses.
[ Edited on 13-5-2007 by Menangler ]
ummmm....yeah..... coolant
So you would most likely undo one of the hoses near the spare wheel where the rubber hose joins the solid tube
