Have been having problem with the buggy when at stand still it sounds as tho the accelerator is engaged (revving slightly higher than normal) when i do engage accelerator and rev it the engine goes back to normal idle??What can i do to try and fix??:cry
Buggy Boyz ·
Check for air leaks and also slop in the main shaft of the Pict carb I am guessing that it has on it.
Sounds like the cause
KruizinKombi ·
Also check that the throttle return spring is still ok and doesn't need replacing.
Sometimes the throttle cable can be the problem also if it is sticking.
