Splitbus narrowed beam (caster corrected)
https://forums.aussieveedubbers.com/threads/62568/splitbus-narrowed-beam-caster-corrected
splitbusaustralia ·
Greetings all,
I have one more K&L splitbus narrowed beam available. New construction (not
cut and welded), caster corrected for lowered bus, new center pin, bushes
and adjusters.
$850 exchange.
I'll probably move to making as requested after this one.
regards
RobK
vsleepy ·
Hi Rob, is this for bushed or needle bearing arms?
splitbusaustralia ·
It's made for either. If you have 64-67 needle bearing
arms you do have to take the sleeves off the outer end
(the tube end of the arms are the same apart from this).
regards
RobK
[ Edited on 24-5-2007 by splitbusaustralia ]
