Pics/diagrams required of \'73 wiring route and question about Indicators.
https://forums.aussieveedubbers.com/threads/62663/picsdiagrams-required-of-73-wiring-route-and-question-about-indicators
hipichic ·
The tinkerbeetle has developed a short, which has resulted in most of the wiring leading to the rear righ taillight melting together.
I've seen/got plenty of schematics, but have nothing on the actual routing of the wiring from front to the rear right (so that I can see where it goes for replacement)....any help would be greatly appreciated.
Thanks!!
Also, if the speedometer is not in the car, would the indicators still work? or does it require the speedo in and hooked up to complete the circuit?
Thanks again!
[ Edited on 21/5/2007 by hipichic ]
blutopless2 ·
speedo does not have to be connected up for indicators to work... however make sure if you have disconnected the wires to the indicators in the speedo that they are not touching the body.
as for the cable route through the car... i think the loom goes down the left hand side of the car to the back then accross the rear seat and into the engine bay area through the rhs.. then it goes off to the taillights.... not 100% sure if this is the case with all models ... but that is how my oval was wired up.
good luck with it.
hipichic ·
Yes, I do believe that is what happened to the wiring 🙁
the wires were just sitting there and I had to start her up to move house. now I potentially have to get the whole wiring loom replaced, oh joy.
