Motor cuts out when you push hard down on brake pedal
https://forums.aussieveedubbers.com/threads/62685/motor-cuts-out-when-you-push-hard-down-on-brake-pedal
Blue Bus ·
Hi there all
Just wondering if anyone could help with a problem on a friends kombi. Its a 2lt twin carb motor all standard and the motor cuts out when you push hard down on brake pedal so where do i look to fix the problem.
Any help would be great.
Cheers Rick
greedy53 ·
break booster sounds like there is a bad leak in the vacume line
and make sure there is not a ddead short in the break line 4 the stop lights
[ Edited on 22-5-2007 by greedy53 ]
Blue Bus ·
Hi there Greedy53
Do you mean where the vacume lines join the brake booster.
Cheers Rick
pod ·
yep check the vacume lines ,from the motor forward to the booster,usually one of the rubber joins has perished
greedy53 ·
for a quick test block of the vacume pipe from the manafold at the manafold than push the stopperl if it don't stop
[ Edited on 23-5-2007 by greedy53 ]
Blue Bus ·
Fixed the problem thanks by replacing the front vacume hoses (the old ones were a bit thin and brittle).
Thanks once again
Cheers Rick
greedy53 ·
there ya go all better
Blue Bus wrote:Hi there all
Try pushing the clutch pedal, too 😂
