hi guys ive been offered a type3 donk for my baja ,and ive been told that i can run it in standard form without the upright cooling system of the type 1 ,is this true ,,,thanx
NO you need to convert it to upright or add some ducting to allow air flow into the engine cooling system
the flayt engine cooling sucks from the rear and when your driving your car along it creatsa vacuum behind the car there for not allowing the engine to suck the cooling air into the fan area.
13bwagon ·
and they look like crap in a t1 and heavy !
aussiebaja ·
im getting it for nothin ,but it needs rings ,ide like a porshe shroud setup but there as dear as poison ,i might look at running some ducting from off the rear guards and onto each side of the motor ,that might work ,,,,
13bwagon ·
a type 3 engine for nothing...
man that to dear
if it needs rings it need more!!!!
and air ducking from guards and t3 flat what kind of holey ,silli vw do you want ???????????
aussiebaja ·
its called something different ,i said i might ,i dont know what to do yet ,plus theres stuff all type 1 around here that they dont want an arm and a leg for
kroozzn63 ·
i put one in my old baja converted easy just a dipstick change and a few bits but yeah go fot it or sell it here and buy a type1 wat eva
aussiebaja ·
thanx kroozzn ,i just didnt know what was involved ,i dont mind if i have to rebuild the engine cause ill do it myself,but i wasnt sure how too run it ,thats what i thought the forums were for to help if someone needs it ,,,thanx again kroozzn
